It is currently Sun Sep 14, 2025 7:00 am
PostPosted: Sat Apr 27, 2024 5:34 am
Country: Ireland
Hi all,
I've built a reasonable few flat tops, mostly l00 sized but nothing for a few years but I'm mulling an archtop. Not a jazz machine, more old time/ blues. I have zero budget but I think all I need to find are top wedges, a violin maker i know days i can borrow a couple of planes for top carving. Ideas so far
L00 sized
Carved spruce top with f holes
'Flat' 15 foot radius back
Back and sides solid mahogany
Bolt on neck accessed through sound port upper bout side
Basically sticking a close as I can to the l-00 design which I know well but with arched top and probably elevated fingerboard extension. Any plans, clues, dimensions for similar instruments, eg vintage l50 etc appreciated. I'm apprehensive as I've played many flat tops and know how they should feel but very little experience with archtops and most of the Internet information is the larger jazz instruments.
Thanks for any tips.
PostPosted: Sat Apr 27, 2024 5:54 am
First name: Ken
Last Name: Nagy
City: Goodrich
Sounds like a fun project. One thing that I did on the one I'm making now, 15 1/4 inch wide, or something like that; is I made the top of 6 pieces of a vertical grain Sitka board I found. The board had some color issues, so I had to fiddle some with placement, but I don't know if you notice it as much when it is carved or not. If I didn't have to move them around, it would have just been 3 pieces.
This will help with your zero budget. Violin and viola wedges are fairly reasonable. Archtop and Cello wedges are pricey. Quartered spruce boards are even harder to find than quartered hardwood boards, but you do come across them.
Why be normal?
These users thanked the author Ken Nagy for the post: mike-p (Sat Apr 27, 2024 5:56 am)
PostPosted: Sun Apr 28, 2024 3:10 am
Country: Ireland
That's good thinking thanks. I'm mostly concerned about getting the neck angle correct and also the shape and thickness of the top. Should I scale down plans for a larger body so I have guides for the carve shape?
PostPosted: Sun Apr 28, 2024 4:36 am
Country: Ireland
Maybe the martin c3 plans would help with the carve?
PostPosted: Sun Apr 28, 2024 6:00 am
First name: Ken
Last Name: Nagy
City: Goodrich
I found that the most reliable way to do arching on violins, cellos, guitars was from the inside out. My newest way is just with tapping and scratching, but it seems that it works easiest if you have some idea what you are going for. If you don't have an instrument in front of you, how do you know; unless you have sculptor vision?
I have a smooth 18" chain I got from walmart. Plated, it doesn't need to be gold or silver! I carve diagonal arches from upper left to lower right, and vice versa. Then fill in with horizontal arches that match up with the diagonals.
You can't finish the diagonals until the horizontals are roughed in too.
How deep you go is determined by how thick your top is. A 3/4" or 18mm board you have to stay about 6mm below that. Thicker or thinner the same way. You probably won't be 6mm thick in the middle; maybe 4.5 or so, but you can make it deeper, and you might find in refining the arch; actually a catenary curve; that you have to make it deeper.
You can't cut this all the way to the edge. You have to have a plan of some sort. Determine where the low point of the outside is around the edge. Unlike violins, and cellos; archtops don't generally have a low point, and a raised edge, but they do have a point where it is finally flat. Go in at least a 1/4" from there.
I like to draw my arch that I expect to get on paper, and then draw the thickness inside of that. Take your chain, tape your drawing on a window upside down, and hold your chain, and see how far out you can go, without going over the line. This distance will be different on the top, bottom and middle.
Where the diagonals cross will not be the high point. The horizontal arch will get higher between the diagonals. The diagonals drop, but for a while, the area below the crossing point, the final center arch will get higher, and then stat dropping.
Violins and Cellos have Strad (the magazine) posters that come with 5 cross arches for the back and belly. The new ones even have ct scans of them. This makes it EASY. Guitar makers don't have that. If your violin maker buddy has posters, especially the new ones, ask if you can borrow them for a while, and you will find what you need to know when doing your archtop.
Planning, and knowing what to expect is a good thing. Doing this, you will find where the bridge location will be. Neck angle isn't as critical as on an instrument with a glued on bridge. It has to be right, but right has leeway on an archtop, or like the viola I just finished.
Draw that out full scale. Know where your slot, and bolts are going to go. Do it the same way that you always do. See what sort of cantilever you can put on the overhang so it is strong, but doesn't look stupid.
Planning is one part I really like. I should take a while. I can go on for weeks.
Why be normal?
PostPosted: Sun Apr 28, 2024 7:25 am
Country: Ireland
Ok this is great information thankyou! I work 7 days a week until November so I may not actually pick up tools until then! I've mostly used a single bolt butt joint for the neck and relied on the glued fb extension to prevent movement without string tension but that's not going to work with the raised fb extension...
PostPosted: Sun Apr 28, 2024 11:36 am
For an archtop bolt on neck the higher angle makes it better to use the Cumpiano barrel nut technique as they can rotate to be square with the headblock. I use two bolts and tighten them with a long Allen wrench through the endpin hole.
PostPosted: Sun Apr 28, 2024 12:39 pm
First name: Freeman
Last Name: Keller
Mike, for what it is worth two years ago I built my first carved top archtop. I basically followed Benedetto's book but a slightly smaller body - 16 inches across the lower bout. I had a non cutaway arched back which I decided to use, that means I could eliminate the issues of bending the cut and making the geometry work out.
I considered a bolt on neck with some sort of access but in end just went with a dovetail and floated the fretboard extension.
I did the top carve in the usual way, started with big wedges of spruce, drilled the outside contour lines and carved the outside arch. Then drilled a fixed thickness (1/4 inch) from the inside and carved to that. Finally thinned the plate towards the recurve. I made templates from Bob's plans, shrunk them slightly for my smaller body.
I debated between X and parallel bracing, the literature indicates that parallel might be louder and X "will typically produce a softer, more mellow sound" (Benedetto), so I went with X bracing. I do have software that allows me to look at the spectrum of various tap tones, not that I know what to do with it. But for what it is worth I did take tap samples all thru the voicing process and they basically followed the predicted changes as I thinned the top, cut the f-holes and finally closed the box.
I don't know if any of this will help you but I did do a build thread at a different forum. Might be worth scanning thru it before you start yours
https://www.tdpri.com/threads/lets-buil ... p.1085372/
I'll add one more thought, I had built a number of flat topped acoustic guitars of various shapes and sizes and consider myself a flat top player. When I first strung up the archtop I hated it. It was almost shrill in its brightness (so much for X bracing), the string squeak was terrible, it seemed to accent all my bad playing. It took a full year of experimenting to find strings that I liked on it and another year for it to finally open up. I now think that its actually a pretty good guitar of its type, I just wasn't used to that sound.
Anyway, consider getting the Benedetto book even if you aren't building that guitar. Enjoy doing the carving, tap and see if you can hear the changes. Play a few guitars of this style so you'll know what you are shooting for. Have fun
PostPosted: Sun Apr 28, 2024 3:15 pm
I actually use hanger bolts as the tenon is square to the neck block. Works well with my extended allen wrench through the endpin hole. Barrel nuts would be fine as well. I just got Marionized way back when.
PostPosted: Sun Apr 28, 2024 3:33 pm
Nowhere near the experience of Alan Carruth and others here but my first guitar in the late 90's was an archtop built using Benedetto's book. I've built a dozen or so since before moving on to flat tops and ukuleles with the first four archtops having dovetails and the rest with bolt on necks. I haven't built any with smaller than 17" lower bouts but have built two bass archtops with 20" lower bouts based on Bill Moll's dimensions and advice. I draw the contour lines carefully by hand based on bridge placement being at the peak of the arch and drill to just above final depth on the lines using Benedetto's methods. I then use a Safety planer to establish ledges based on the drilled depths and then hand planes etc. from there. Same for the inside arch which is done after the top carve. I did use a Kutzall carving disc on an angle grinder for the two basses as it was a ridiculous amount of carving otherwise. The Safety planer also makes it easy to establish the 1/4" ledge around the perimeter. The neck angle is easily mapped out by drawing it out to scale, knowing the height of the highest point of the top plate and allowing for an 1" or so bridge height if you're following Benedetto's measurements for a 17". Scribing the fretboard extension based on the bridge height and then slowly carving it down to the "overstand" height using carbon transfer paper (mostly 1/2" skew chisels for me) to reach the desired fretboard plane to bridge height is slow but not difficult. Looking forward to seeing what you come up with.
PostPosted: Wed May 08, 2024 5:18 am
City: Escondido
Zip/Postal Code: 92029
Even though I’ve given up on building, I’ve built a fair number of archtops, and pretty much play them exclusively. FWIW, I’ll share my experience as principally a player and secondarily a builder.
First thing I would say is that an archtop as an instrument is not a cool looking dreadnaught. It is a different instrument best suited to a different musical purpose. Oversimplified, a dreadnaught is an excellent accompaniment to vocals. Compared to other stringed instruments it has boomy lows and sparkling highs giving a human voice space. A good acoustic archtop is more balanced in the midrange. By comparison it may sound harsh, especially if you are playing cowboy chords and trying to sing songs over them. If you are playing single lines or what jazz players call chord melody the purity of the notes and note separation is unmatched. A bit like a small bodied flat top set up for finger style, but with more projection, dynamic range, and way more volume.
But… archtops have a schizophrenic history. Their heyday also is the dawn of electric guitars. For many players, an archtop is first and foremost an electric guitar. As a result there is a wide spectrum of acceptable archtops. There is a lot of conflicting information on what makes a “good” archtop because there is a bigger spectrum of acceptable uses than you find among pre-war Martin D-28 copies. Benedetto built acoustic oriented guitars, a Gibson ES175 is meant to be plugged in. Build to your purpose.
When I gig (rarely) it is solo and without vocals. I like to mic a guitar rather than plug in. My building journey was for that goal. I discovered that, while Benedetto was building for acoustics, the book measurements are WAY over built. The rumor was that the publisher made him add 1/16” to the measurements to avoid complaints, but that’s probably just a tall tale. I kept going thinner and thinner to get a sound I was pleased with. Eventually, I departed from Benedetto entirely.
If you want an acoustic 15” archtop for solo acoustic playing you will likely carve it much thinner than Benedetto’s book and you will likely need very little bracing. I also think a small acoustic archtop defeats the point. For that an OO will do fine. The archtop is there to project and be heard. But that’s just my opinion.
If you just like the looks of an archtop and want a build challenge, I recommend you build it as an electric guitar. You may even want to extend the neck block to under the bridge to mount pickups and bridge posts in. What I think of as an “airy” semi. I built a couple of semis and LOVED playing them. My Tele never was loved the same again.
Whatever you choose, archtops are great projects and you will end up with a guitar people will always comment on and gravitate to. Good luck and have fun!
These users thanked the author rlrhett for the post: Kbore (Thu Dec 12, 2024 8:49 pm)
PostPosted: Wed May 08, 2024 7:18 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
We did a lot of solid-top and laminated archtop work at Greenridge, to include scale length conversions taking 17" bodies to shorter scale length (580mm) for conversion to 8 string guitar-shaped Greek bouzoukis and 3-4 arched top/flat-backed octave mandolins (I don't recall the exact number... was early days for me with that shop). The most important 'tool' for planning was the full-sized profile of the instrument, worked from known scale length and the top center-line profile. Unknowns with regard to neck attachment, truss rod integration, and such mundane considerations as tailpiece resign were quickly resolved once that initial profile was lofted... questions with regard to dovetail versus bolt-on access geometry, etc. were answered in a direct fashion.
Our bouzouki conversions on Ibanez Artcore archtops in particular were informed by use of these profile views, as we used a Martin two-way adjustable truss rod with access via a hidden channel through the semi-cantilevered fretboard extension. Working access issues out on paper (or these days in Fusion 360) allowed for that approach as well as the bolt-on conversion.
On the 00-sized guitar-shaped octave mandolins, I believe a scaled profile from Mr. Benedetto's book was used for both the center line top profile and the upper and lower bout top contours. The rim was deepened versus the usual shallower arched-top/arched-back practice with use of this developed profile view as well, and fit in a 00-sized case confirmed with a full-sized profile view template pasted to 1/4" MDF stock. Those instruments used red spruce 6- and 8-piece tops gotten out of some Canadian-sourced 2x4 stock... as mentioned, patience and diligence will turn up a couple suitable sticks over time, although be prepared to restack the culled wood if you don't wish to endure the side-eye from the people working in the lumber department.
Good luck with your project
- Beth Brower
These users thanked the author Woodie G for the post: Hesh (Wed May 08, 2024 1:39 pm)
PostPosted: Thu May 09, 2024 8:55 am
Country: Ireland
This is all great stuff thankyou, I guess it'll be along the lines of the Waterloo WL-AT anyone had their hands on one of those?
PostPosted: Mon Jun 24, 2024 5:37 pm
Country: Ireland
Thanks again for all the time spent typing out answers
I'm getting closer to thinking about starting... I can borrow a violin plane but I think I need a gouge. What size and profile would you recommend if you only get one?
PostPosted: Tue Jun 25, 2024 10:58 am
I use this one a lot in 3/4" mostly for the inside. https://www.leevalley.com/en-ca/shop/to ... em=58D2009
PostPosted: Mon Jul 01, 2024 3:03 am
Country: Ireland
Any thoughts on body depth and taper people? Waterloo lists 4 inch depth but I can't tell if it tapers. I'm thinking 4" deep no taper with back purfling a little proud and then profiled to fit the 15 foot back radius.
These users thanked the author mike-p for the post: Ken Nagy (Mon Jul 01, 2024 5:55 am)
PostPosted: Mon Jul 01, 2024 6:23 am
First name: Ken
Last Name: Nagy
City: Goodrich
I was just scrolling and hit the thanks button. I guess it's better than hitting the call button. I've done that.
"No, I didn't really want to call you."
I really don't know what a flat backed archtop is. I've never seen one. The Benedetto book has it 3" thick, I think. No taper. The flat back might be deeper because of no arch? I've only done one flat top. I found the back is simple to arch with a form to glue the braces in. But I saw a much easier idea. Bend the braces to fit in the linings. Have them set so you get a nice curve both ways. It will not be a radius. Close, but it is a catenary curve. Put glue on the braces, and glue your back on with rope.
When it is dry, lift the back, with the braces out of the linings. Tune the braces up, and glue it in the braces.In this case; the braces are doing the job of holding the back on. The edge/linings don't really have to be perfect. Plane them so the outside ledge is lower. The edge/lining will glue somewhere along the edge. The blocks and the braces are the main glue points that matter.
The place I saw this idea didn't say that. But that is the way it is.
The binding will further secure the back in place. It isn't going anywhere. You can experiment with how much bend you want in the back. I suppose mostly for looks, but a lower bend might need thicker bracing. A higher bend might need a more flexible back; in material, or thickness. Tuning the braces will get the back where you want it.
Why be normal?
PostPosted: Mon Nov 25, 2024 5:09 pm
Country: Ireland
Right I gathered up my cents and bought a single A European spruce pair of wedges. Visited a violin making friend and watched her rough gouge a spruce top which was unbelievably helpful. She scribes the thickness around the edge roughly draws the area on the top which she wishes to be flat. Then draws a line in from the edge the rough depth of her recurve, makes the recurve area flat then carves from there to the edge of the top flat area.
How wide a recurve would you guys suggest? I've tried eyeballing pictures of archtops.
The picture I've hopefully attached is my plate with the body drawn, the recurve area inside of that and then the flatter area marked out in the middle with the Bridge and saddle roughly marked in place. Am I heading in the right direction?
PostPosted: Mon Nov 25, 2024 5:15 pm
Country: Ireland
Edge - recurve/flat- central bridge areaImage
Sent from my SM-G981B using Tapatalk
PostPosted: Mon Nov 25, 2024 5:53 pm
I just got to this thread, and the info I can offer is a bit late for your current project, but maybe somebody else can use it.
A friend of mine and his wife worked up an Android app called 'Luthier Lab' that you can download free. There is a module in it for drawing outlines, which can be printed out full size, and another that will produce a set of cross arch patterns for a given outline based on the lengthwise arch using the 'curtate cycloid' method. It can print this out full sized as a contour map as well. I've used this system on archtop guitars and fiddles and it works well.
PostPosted: Tue Nov 26, 2024 8:43 am
First name: Ken
Last Name: Nagy
City: Goodrich
You can watch all of the Ken Parker Archtoppery videos. One thing that I noticed about his builds is that he uses an adjustable neck. It seems complicated; but I don't think that it is that much harder (I haven't done one yet.
I wondered how he can just raise and lower the neck to adjust the action. The other day I noticed that his neck angle is set high, and the angle is very flat. He doesn't go into that; at least I haven't seen it; but it is an idea. It is especially useful, if like Ken, and me, you like solid bridges. It is adjusted with a single small adjusting screw with right and left hand threads.
I do all my carved instruments with curdate cycloids. Even the last ones where I carved them by tapping and scratching, I set the initial thicknessing and shape of the Edgewook with the cycloids set to what I supposed that the long arch would be. They all came out like cordate cycloids; so there is something to it.
On guitars, you usually place all the low points right on the edge; or maybe just inside any purfling that you put in; and the roll up from there. They are VERY flat in comparison to violins and violas; cellos get closer to arch tops. You can easily find the points for 8 places on the arch just calculating for every 45 degree of rotation of the imaginary spirograph disc.
I just use math and trig to figure these points out. I just saw this link. I haven't used it; but I bet it is a lot simpler. I've done the other way for years, and just punch numbers in on the calculator.
https://www.liutaiomottola.com/formulae/curtate.htm
I used to have an online cycloid calculator that would give you a drawing to print, and a sheet with coordinates for points along it; at every degree or something ridiculous like that. I don't know what that was called.
Why be normal?
PostPosted: Thu Nov 28, 2024 6:45 pm
Country: Ireland
Thankyou good people! I am still keeping away from the gouge and planning, thanks for mentioning the archtoppery again. I watched a few but I got bored with videos on making the mould/ nest thing to hold the top while carving but I'm watching the roughing plates ones now and learning plenty. Mostly that I need to up my sharpening game...
PostPosted: Wed Dec 11, 2024 6:48 pm
I am an outliar when it comes to "carving" an Archtop....
I don't use a plane at all,I only use The Lancelot carver,a 36 grit disc on a 4"grinder, a Festool 6"random orbit sander and a Festool 5" sander...
I have always done it that way and it has worked well for me.
I am always hesitant to reccommend the Lancelot carver because of the inherent danger of that tool, but the 36 grit alone would get you there albeit slower...
PostPosted: Wed Dec 11, 2024 7:59 pm
ever tried 24 grit?
I used to use that for coping typical 8012 crown moulding...could do it in less than 60 seconds with a back cut angle that for all intensive purposes cut itself into the piece it was butting into
PostPosted: Wed Dec 11, 2024 10:30 pm
I've used a Kutzall disc in the past as well. Slower than a Lancelot but faster than 40 grit.
Users browsing this forum: No registered users and 88 guests
